First time Qubues install from USB and I get the following (apologies it’s a vague type up because I don’t actually know how to access any logs because I can’t get anywhere)
[Failed] Failed to start udev wait for complete device initialization
see systemctl status systemd.udev.settle.service for details
audit type=1334 audit(NUMBERS) prog-id=5 op=UNLOAD
systemd-gpt-auto-generator EFI loader partition unknown exiting
the boot loader did not set the EFI ariable LoaderDevicePart UUID
nvme0 missing or invalid SUBNQN field
nvme0 I/O 25 QID 0 timeout, connection polled
nvme1 I/O 25 QID connection polled
etc.
Could this be a Ryzen7 issue and is there a relatively easy way to solve this? I have tried the new kernal in the boot options and also couldn’t get to TTY.
>>inxi -CG
CPU:
Info: 8-core model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 1785 min/max: 1600/4784 cores: 1: 3200 2: 1600 3: 1600
4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 9: 1361 10: 1600 11: 3200 12: 1600
13: 1600 14: 1600 15: 1600 16: 1600
Graphics:
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] driver: nvidia
v: 535.54.03
Device-2: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting dri: radeonsi
gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~144Hz
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX 3050
Laptop GPU/PCIe/SSE2
