To make my hard drive not unmounted after every computer suspend, I attached it persistently with the following command (Qubes 4.0):
“qvm-usb attach --persistent example-VM sys-usb-dvm:3-3”
But after the computer rebooted, the example-VM would not start because sys-usb-dvm:3-3 would not be available. In fact, the hard disk was named sys-usb-dvm:4-3 in the meantime.
With “qvm-usb d example-VM sys-usb-dvm:3-3” I cannot remove the persistent option. It is still present in /var/lib/qubes/qubes.xml. What now?
Is there a way to give a drive a persistent name, so that it is always sys-usb-dvm:3-3?
Or is it possible, even without using the persistent command, to make sure that the disk is not detached after suspend?
Can I somehow remove the persistent option on the command line?
