USB Devices not working after reboot
1.After installing Qubes 4.3 and setting the default to accept all USB devices
2.After a few reboots after the decryption screen the USB devices don’t receive any power.(Literally just doing office work)
  1. I have installed Qubes 4.3 twice and this has happened twice now. On 4.2.4 This issue was not present.
I’m confused. Doesn’t the decryption screen appear on every reboot? Do you mean after sleeping the computer a few times?
“Yes”
I don’t have good luck sleeping computers and laptops in Linux so tend to shut them down when I’m not using them. I know that isn’t super helpful . . . . I guess you could try checking the sys-usb logs (Qube manager and right-click on sys-usb) and post them here in case someone has an idea.
Oh no the issue is untrusted hardware my bad, I hope your hardware gets fixed also. Risk-V looks quite impactful.
