Thinkpad P51, which has one USB-C 3.1 port (Thunderbolt 3).
Qubes OS 4.2 fresh install.
If no device is connected to the USB-C port at the time of boot, then a flash drive or USB-C hub is not discovered when connecting it after the OS has started.
However, if a flash drive is connected at the time of boot, then it is shown in the list of devices, then it works fine, and I can attach it do individual VMs.
The following surprises me most: If an USB-C hub was connected to USB-C at the time of boot, then it works to hot-plug flash drives at Qubes runtime.
I wonder if there is a plausible explanation of this behavior, or if it seems like a hardware/BIOS bug.
I haven’t yet tried to boot a live USB system on that laptop, to check whether the behavior is the same with other Linux flavors.
USB-A and USB-C are controlled independently. Read user manual. Snippet below . . .
After you install another operating system, you can enable the Thunderbolt 3 technology in ThinkPad Setup by doing the following:
1. Restart the computer and press F1 when the logo screen is displayed. 2. Select Config ➙ Thunderbolt™ 3 ➙ Security level. 3. Change the settings from Display Port and USB to any other selection.
Trying different related BIOS options didn’t have any impact on the reported behavior.
However, I noticed one more interesting detail.
It isn’t necessary to do a full reboot to get Qubes to discover the device connected to the USB-C port.
It is sufficient to restart the qube that handles the USB devices. (In my scenario, it’s sys-net which handles USB, too.)
So it doesn’t look like a BIOS issue, but rather an issue at the Qubes level? Is it possible that Qubes doesn’t re-scan the USB-C port during runtime, but only scans it on initial startup of the respective USB qube?
Do you need to have USB device connected during sys-usb restart?
Or if you restart sys-usb without USB device connected and connect USB device after sys-usb is started then it’ll work?
Do you see anything in sys-usb log when you connect the USB device and it’s not recognized?
Restart sys-usb without USB device connected.
Run in sys-usb terminal:
