Hello,
on https://ftp.qubes-os.org is just saw that rc4 was uploaded and recently i had installed a rc3 test system on a second laptop.
Is there a way to upgrade between rcs? I didnt found anything in the docs and qubes-dist-upgrade just accepted --releasever=4.3 and not =4.3-rc4
Am i just too stupid to find the way to do this or is it not supported?
Or is an normal update from dom0 enough to download the new packages?
Hi
If you do your normal updating procedure, your system will be automatically upgraded from rc3 to rc4. You could confirm this (after updating system) by going to App Menu → Settings → Qubes Tools → Qubes Global Config → This Device Tab → Qubes OS Version.
can you specify “normal updating procedure”? do you mean dom0 update via qubes update gui or a cmd for qubes-dist-upgrade or something else?
Yes. Updating via GUI updater or qubes-dist-upgrade
Any info on when -rc4 will be released?
Very soon:
I can confirm that that procedure works. I started twith rc3 (around 2025.11) and I’m now on rc4. Updating over UI (dom0) when the system anounced that an update was available.
