Context: Trying to migrate:
- from my old PC (Qubes R 4.1.2)
- to my new PC (Ques R 4.2.4 - Clean Installation)
Steps on my old PC:
I followed https://www.qubes-os.org/doc/upgrade/4.2/, meaning I:
ran the updater
installd the qubes-dist-upgrade tool (
sudo qubes-dom0-update -y qubes-dist-upgrade) -
typed this command in a dom0 terminal:
qubes-dist-upgrade --template-standalone-upgradeand got:[user@dom0 ~]$ sudo qubes-dist-upgrade --template-standalone-upgrade INFO: Please wait while running pre-checks... usage: qvm-check [--verbose] [--quiet] [--help] [--all] [--exclude EXCLUDE] [--running] [--paused] [--template] [--networked] [VMNAME [VMNAME ...]] qvm-check: error: no such domain: 'CUST0001' WARNING: /!\ MAKE SURE YOU HAVE MADE A BACKUP OF ALL YOUR VMs AND dom0 DATA /!\ -> Launch upgrade process? [y/N] y ERROR: Cannot continue to STAGE 4, dom0 is not R4.2 yet. Any error happened in previous stages? [user@dom0 ~]$NB: I have no idea what âCUST0001â is.
I did nothing more here.
backed up my VMs
Steps on my old PC:
I:
installed Qubes R 4.2.4
hit the
Restorebutton on a Qube Manager window and gave the VMs to be restored -
got this log on the restoration window:
Name of the VMs to be restored:
-> Restoring <VM-name-1>... -> Restoring <VM-name-2>... -> Restoring <VM-name-3>... ... -
Then, error messages due to eth card not being pci:03_00.0 on the new PC ==> Fine:
Error attaching device pci:03_00.0 to <VM-on-old-PC-where-eth0-was-attached>: Invalid PCI device: 03_00.0 Error attaching device pci:03_00.0 to <other-VM-on-old-PC-where-eth0-was-attached>: Invalid PCI device: 03_00.0 -
Then, the amount of data to be restore:
Extracting data: 289.2 GiB to restore -
Then, after a bit of time, the same sequence of error messages for many VMs to be restored:
Failed to restore volume root (size 21474836480) of VM <VM-NAME-X>: Cannot create new thin volume, free space in thin pool qubes_dom0/vm-pool reached threshold. Error while processing '/home/user/QubesIncoming/backup#restore-wmmuzuqu/vm51/root.img.000': ERROR: unable to extract files for /home/user/QubesIncoming/backup#restore-wmmuzuqu/vm51/root.img.000, tar output: Failed to restore volume private (size 5368709120) of VM <VM-NAME-X>: Cannot create new thin volume, free space in thin pool qubes_dom0/vm-pool reached threshold. Error while processing '/home/user/QubesIncoming/backup#restore-wmmuzuqu/vm51/private.img.000': ERROR: unable to extract files for /home/user/QubesIncoming/backup#restore-wmmuzuqu/vm51/private.img.000, tar output: -
Then, the closing:
Restoring home of user 'user' to 'home-restore-2025-06-17-191920' directory... -> Done. -> Please install updates for all the restored templates. Finished successfully!
Additional info:
On my new PC, I dedicated 900 GiB to Qubes, which is more than on my old PC
df -hon dom0, after the (unsuccessfull) installation:Filesystem Size Used Avail Use% Mounted on devtmpfs 4.0M 0 4.0M 0% /dev tmpfs 2.0G 24K 2.0G 1% /dev/shm tmpfs 779M 2.3M 777M 1% /run efivarfs 64K 34K 25K 58% /sys/firmware/efi/efivars /dev/mapper/qubes_dom0-root 885G 6.8G 834G 1% / tmpfs 2.0G 44K 2.0G 1% /tmp /dev/nvme1n1p2 974M 138M 769M 16% /boot /dev/nvme1n1p1 599M 32M 568M 6% /boot/efi tmpfs 390M 112K 390M 1% /run/user/1000 -
Afterwards, I installed Qubes R 4.2.4 again from scratch and I tried to restore only 2 VMs (a VM and itâs template). I did not get any error message and the restoration of both VMs looks OK at first sight.
Afterwards, I went on and tried to restore 15 VMs at the same time ==> I got the error messages
During that restoration, every time I looked,
/dev/mapper/qubes_dom0-rootâs use was always <= 5% (obviously, I was not constantly watching) -
New PC is Qubes certified
Questions:
- Why all those error messages when I try to restore all of the VMs at the same time
- What should I do to be able to restore all of my VMs in one batch?
