*Edit: Ok, so I have been reading some other posts and it seems this is a known problem and a fix is on the way.
Hello,
I recently installed Qubes for the first time and immediately started by updating all the templateVMs. When it came to updating the Fedora template it mostly worked but I also got this:
Problem 1: package pulseaudio-qubes-4.0.31-1.fc32.x86_64 requires pulseaudio = 13.99.1, but none of the providers can be installed
- cannot install both pulseaudio-14.0-1.fc32.x86_64 and pulseaudio-13.99.1-4.fc32.x86_64
- cannot install both pulseaudio-13.99.1-3.fc32.x86_64 and pulseaudio-14.0-1.fc32.x86_64
- cannot install the best update candidate for package pulseaudio-qubes-4.0.31-1.fc32.x86_64
- cannot install the best update candidate for package pulseaudio-13.99.1-4.fc32.x86_64
Problem 2: package qubes-vm-recommended-4.0.7-1.fc32.noarch requires pulseaudio-qubes, but none of the providers can be installed - package pulseaudio-qubes-4.0.31-1.fc32.x86_64 requires pulseaudio = 13.99.1, but none of the providers can be installed
- package pulseaudio-13.99.1-4.fc32.x86_64 requires pulseaudio-libs(x86-64) = 13.99.1-4.fc32, but none of the providers can be installed
- package pulseaudio-13.99.1-3.fc32.x86_64 requires pulseaudio-libs(x86-64) = 13.99.1-3.fc32, but none of the providers can be installed
- cannot install both pulseaudio-libs-14.0-1.fc32.x86_64 and pulseaudio-libs-13.99.1-4.fc32.x86_64
- cannot install both pulseaudio-libs-13.99.1-3.fc32.x86_64 and pulseaudio-libs-14.0-1.fc32.x86_64
- cannot install the best update candidate for package qubes-vm-recommended-4.0.7-1.fc32.noarch
- cannot install the best update candidate for package pulseaudio-libs-13.99.1-4.fc32.x86_64
Problem 3: problem with installed package pulseaudio-qubes-4.0.31-1.fc32.x86_64 - package pulseaudio-qubes-4.0.31-1.fc32.x86_64 requires pulseaudio = 13.99.1, but none of the providers can be installed
- package pulseaudio-module-bluetooth-14.0-1.fc32.x86_64 requires libpulsecore-14.0.so()(64bit), but none of the providers can be installed
- package pulseaudio-module-bluetooth-14.0-1.fc32.x86_64 requires pulseaudio(x86-64) = 14.0-1.fc32, but none of the providers can be installed
- cannot install the best update candidate for package pulseaudio-module-bluetooth-13.99.1-4.fc32.x86_64
Problem 4: problem with installed package qubes-vm-recommended-4.0.7-1.fc32.noarch - package qubes-vm-recommended-4.0.7-1.fc32.noarch requires pulseaudio-qubes, but none of the providers can be installed
- package pulseaudio-module-x11-14.0-1.fc32.x86_64 requires libpulsecore-14.0.so()(64bit), but none of the providers can be installed
- package pulseaudio-module-x11-14.0-1.fc32.x86_64 requires pulseaudio(x86-64) = 14.0-1.fc32, but none of the providers can be installed
- cannot install the best update candidate for package pulseaudio-module-x11-13.99.1-4.fc32.x86_64
Skipping packages with conflicts:
(add ‘–best --allowerasing’ to command line to force their upgrade):
pulseaudio 13.00.1-3.fc32
pulseaudio 14.0-1.fc32
pulseaudio-libs 13.99.1-3.fc32
pulseaudiolibs 14.0-1.fc32
Skipping packages with broken dependencies
pulseaudio-module-bluetooth 14.0-1.fc32
pulseaudio-module-xll 14.0-1.fc32
So I typed 'sudo dnf update --best --allowerasing" it worked, but now my laptop can’t play audio anymore. Not through the speakers and not through the headphone jack. I eventually had to reinstall Qubes because I couldn’t fix it.
I think it’s pretty clear that relatively new to Linux having only used Mint for about a year and a half or so before switching to Qubes, but if anyone could point me in the right direction here so I could update the fedora template and still have audio that would be immensely appreciated.
Thanks!
