I can not update dom0 using qubes OS updater. These are the errors when updating
Updating dom0...
Detailed information will be displayed after update.
dom0 does not support in-progress update information.
Error on updating dom0: Command '['sudo', 'qubesctl', '--dom0-only', '--no-color', 'pkg.upgrade', 'refresh=True']' returned non-zero exit status 1.
[ERROR ] Command 'systemd-run' failed with return code: 134
[ERROR ] stdout: e[0;31m0 files removed
e[0m
[ERROR ] stderr: Running scope as unit: run-r7de24a29fd374156a6eb0bda1427c894.scope
Using sys-whonix as UpdateVM to download updates for Dom0; this may take some time...
warning: Converting database from sqlite to bdb backend
Unable to detect release version (use '--releasever' to specify release version)
python3: ./libdnf/dnf-sack.cpp:723: gboolean load_yum_repo(DnfSack*, HyRepo, GError**): Assertion `fp_primary' failed.
Aborted (core dumped)
[ERROR ] retcode: 134
Error running 'pkg.upgrade': Problem encountered upgrading packages. Additional info follows:
changes:
result:
pid:
1619153
retcode:
134
stderr:
stdout:
0 files removed
