Last update removed my kernel and initramfs files.
Whats the intended set of packages to reinstall to fix this?
Its kernel{|-latest}{,-modules}($version)
They were marked installed but kernel and initramfs files missing.
Uninstalling them with dnf and reinstalling them using qubes-dom0-update regenerates them.
It does not work with the metapackage nor the currently running kernel version.
You have to specify the version for it to work.
The metapackge is in the list of protected packages and cant be removed.
