Update 4.3-rc4 to 4.3.0: Errors metadata for repository 'qubes-contrib-dom0-r4.2-current'
Did a fresh install of 4.3-rc4 last week and try to update to 4.3.0. via
sudo qubes-dom0-update
Get error message:
Errors during downloading metadata for repository 'qubes-contrib-dom0-r4.2-current'
Cannot download repomd.xml. All mirros were tried.
What did I wrong?
You forget:
sudo qubes-dom0-update -y qubes-dist-upgrade
qubes-dist-upgrade --releasever=4.3 --template-standalone-upgrade -y
source: Qubes OS 4.3.0 has been released! | Qubes OS
Thx, but still the same behavior.
Perplexity helped me:
In
/etc/yum.repos.d/qubes-contrib.repo
In Section [qubes-contrib-dom0-r4.2-current] enabled=0
Then the steps you mentioned.
Now anything is fine again.
Case can be closed.
