I saw below invalid dns queries from debian-minimal based app-vm on the pihole logs.
- AAAA, https
- A, https
- SRV, _http._tcp.https
- A, 0t
- AAAA, 0t
I could trace the first three calls to the library /usr/lib/apt/methods/http. The fourth and fifth calls does not occur often and I could not trace it.
I also think the http library is run when the service qubes-update-check runs.
Any idea on why the library /usr/lib/apt/methods/http is making invalid dns queries and how can I stop them? I did blacklist the calls in pihole, but I would like to stop them at the source.
Edit: Part of the problem is because I am using apt-cacher-ng and sources in sources.list begins with http://HTTPS//, so I guess the library is making dns request to https.
So my new questions are
why is the service qubes-update-check runs in app-vm?
why it does not use updates-proxy to check for updates?
Is it okay to turn off this service in app-vm?
