Unrecognized default-dvm internal qube starts at log in
when I log in to my system a grayed out default-dvm “disp893” starts, where the only options in the Qubes Domains panel menu are: “internal qube, console log, kill”
what is this for? Is there a way/would it be okay to disable it? thank you.
It is a preloaded disposable, how it is displayed should change. See related issue:
If you still want to disable it:
thank you for the prompt reply. I agree with the issue’s OP that this should be explained somewhere. it’s surprising that I couldn’t find any posts about it here. solved
There have already been a number of posts on the subject in the Forum.
