"Unknown error" during installation
Hello all,
I’m trying to install QubesOS 4.3.0 on a laptop (XPS 15 9550), from a USB drive (Ventoy, UEFI) and I have this error during the installation, few minutes after choosing install options and launching install : qubes hosted at ImgBB — ImgBB
OCRed error is as follow :
anaconda 41.28 exception report
Traceback (most recent call first):
  File "/usr/lib/python3.13/site-packages/dasbus/client/handler.py", line 509, in _handle_method_error
    raise exception from None
  File "/usr/lib/python3.13/site-packages/dasbus/client/handler.py", line 483, in _get_method_reply
    return self._handle_method_error(error)
  File "/usr/lib/python3.13/site-packages/dasbus/client/handler.py", line 450, in _call_method
    return self._get_method_reply(
  File "/usr/lib64/python3.13/site-packages/pyanaconda/modules/common/task/__init__.py", line 46, in sync_ru[n]
I’ve checked ISO before trying installation (signature and hash).
Anyone have an idea of the problem ?
Thanks
Your error message seems incomplete, there should be more stuff after the last File line. Also it would be really useful if you could post the logs. Here’s the installation troubleshooting doc:
Thanks for your answer, I’ll post logs once I come back home.
About that, is it supposed to be done using the “debug” feature in order to extract them from /tmp/*.log ?
Qubes install doesn’t work with ventoy. Do a search and you’ll see numerous threads. Use dd
Experiencing this issue as well. I hope it gets resolved before 4.2 EOL.
Also, I did flash the ISO with dd.
