Tanks you for your time to reply.
Blockquote You’ll see the sys-net NetworkManager applet in the dom0 tray and you can configure your network using it.
At the dom0 tray appears the Ethernet connection, but nothing wireless.
Blockquote What’s your USB network adapter (model or VID:PID)? Is it WiFi or Ethernet?
Using lsusb it says is 0bda:b832. The chipset is rtl8832bu Realtek.
The command sudo journalctl -f -n0 prompted:
May 28 19:47:04 sys-net kernel: usb 4-1: new high-speed USB device number 6 using xhci_hcd
May 28 19:47:05 sys-net kernel: usb 4-1: New USB device found, idVendor=0bda, idProduct=1a2b, bcdDevice= 0.00
May 28 19:47:05 sys-net kernel: usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 28 19:47:05 sys-net kernel: usb 4-1: Product: DISK
May 28 19:47:05 sys-net kernel: usb 4-1: Manufacturer: Realtek
May 28 19:47:05 sys-net systemd[1]: Created slice system-usb_modeswitch.slice - Slice /system/usb_modeswitch.
May 28 19:47:05 sys-net systemd[1]: Starting usb_modeswitch@4-1.service - USB_ModeSwitch_4-1...
May 28 19:47:05 sys-net systemd[1]: usb_modeswitch@4-1.service: Main process exited, code=killed, status=15/TERM
May 28 19:47:05 sys-net systemd[1]: usb_modeswitch@4-1.service: Failed with result 'signal'.
May 28 19:47:05 sys-net systemd[1]: Stopped usb_modeswitch@4-1.service - USB_ModeSwitch_4-1.
May 28 19:47:05 sys-net kernel: usb-storage 4-1:1.0: USB Mass Storage device detected
May 28 19:47:05 sys-net kernel: usb-storage 4-1:1.0: device ignored
May 28 19:47:05 sys-net kernel: usbcore: registered new interface driver usb-storage
May 28 19:47:05 sys-net kernel: usbcore: registered new interface driver uas
May 28 19:47:05 sys-net usb_modeswitch[2228]: switch device 0bda:1a2b on 004/006
May 28 19:47:05 sys-net kernel: usb 4-1: USB disconnect, device number 6
May 28 19:47:06 sys-net kernel: usb 4-1: new high-speed USB device number 7 using xhci_hcd
May 28 19:47:06 sys-net kernel: usb 4-1: New USB device found, idVendor=0bda, idProduct=b832, bcdDevice= 0.00
May 28 19:47:06 sys-net kernel: usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 28 19:47:06 sys-net kernel: usb 4-1: Product: 802.11ac WLAN Adapter
May 28 19:47:06 sys-net kernel: usb 4-1: Manufacturer: Realtek
There’s not any MAC, should it appear there?
At first I though it was an issue related to usb_modeswitch because of
May 28 19:47:05 sys-net systemd[1]: usb_modeswitch@4-1.service: Main process exited, code=killed, status=15/TERM May 28 19:47:05 sys-net systemd[1]: usb_modeswitch@4-1.service: Failed with result 'signal'.
But it doesn’t seems to be the problem because in my other machine the same message is displayed.
