Mirage-firewall vm was installed on a fully updated Qubes installation, with the latest mirage-firewall tar.
When I have sys-net connected as mirage-firewalls Netvm, everything works as expected. When I remove the net-vm, mirage-firewall refuses to shutdown, and qubes with mirage-firewall as their netvm will not start either. Eventually I get a libxenlight error after time from initiation of shutdown.
The errors from logs I get (I can get more on request) are:
In /var/log/libvirt/libxl/libxl-driver.log
libxl_domain.c:853:pvcontrol_cb: guest didn’t acknowledge control request: -9
When I grep mirage-firewall in journalctl:
unhandled exception while calling src=b’dom0’ meth=b ‘admin.vm.shutdown’ dest=b’mirage-firewall’ arg=b’’ len(untrusted-payload)=0
If I attach a VM with mirage-firewall as its net-vm when mirage-firewall is up but has no net-vm itself, I get:
Start Failed: internal error: libxenlight failed to create new domain ‘openbsd-21-sysnet’, see /var/log/libvirt/libx/libxl-driver.log for details.
In libxl-driver.log:
libxl_device.c:1146:device_backend_callback: Domain 25:unable to add device with path /local/domain/21/backend/vif/25/0
libxl_dm.c:2761:stubdom_pvqemu_cb: Domain 24:error connecting nics devices: Resources temporarily unavailable
libxl_dm.c:2800:stubdom_xswait_cb: Domain 24:(null): startup timed out
libxl_create.c:1913:domcreate_devmodel_started: Domain 24:device model did not start: -9
libxl_device.c:1434Llibxl_wait_for_backend: Backend /local/domain/0/backend/pci/25/0 not ready
libxl_device.c:1146Ldevice_backend_callback: Domain 25:unable to remove device with path /local/domain/23/backend/vif/25/0
libxl_domain.c:1553Ldevices_destroy_cbL Domain 25Llibxl_devices_destroy failed
The reason I want to have mirage-firewall run without an assigned net-vm is that I want it to work with an OpenBSD netvm, and so it must have no netvm attached to it.
No devices are attached to the mirage-firewall VM.
What might the issue be here?
