So, I’ve also been trying to setup a vpn using the qubes contrib method. So I installed qubes-repo-contrib package using apt-get on a debian minimal 12 template and it seemed to go fine (no errors) but then I tried to install qubes-tunnel:
sudo apt install qubes-tunnel
reading package lists... Done
Building dependency tree ... Done
Reading state information... Done
E: Unable to locate package qubes-tunnel
I tried to install something else, terminator in this case and it finds terminator asks if i want to install it, then starts spitting things out like “Temporary failure resolving deb.debian.org”?
Its not clear to me why it can “see” some packages but then not be able to download them?
I’ve run sudo apt-get update && sudo apt-get upgrade a few times and it tells me some index files failed to download. Any thoughts why this might be happening?
Qubes-tunnel package is currently in Qubes contrib updates testing repository (bookworm-testing).
You need to enable this repository in /etc/apt/sources.list.d/qubes-contrib-r4.2.list:
# Qubes contrib updates testing repository
#deb [arch=amd64] https://contrib.qubes-os.org/deb/r4.2/vm bookworm-testing main
#deb-src https://contrib.qubes-os.org/deb/r4.2/vm bookworm-testing main
Then install qubes-tunnel package from testing repository:
Thanks.
So I enabled the testing repo (un-commented those two lines in the `/etc/apt/sources.list.d/qubes-contrib-r4.2.list) ok, then update seemed to go ok, but then when I ran:
