Is there a way to easily type accented letters in Qubes, mainly in word or document processors? I use LibreOffice Writer frequently and would like to be able to type accented letters with a compose key, which I remember doing in Pop OS. If there was another easy way of typing accents I would be welcome to that.
I am currently using a testing release: R4.1 from Open-QA (build 03-27-2021).
On other distros, I have enabled a compose key via Gnome-Tweaks, and have tried installing Gnome-Tweaks on Qubes and enabling a compose key, first in my AppVM, just to test, and then my TemplateVM (Fedora-33), but that did not work. Would Gnome-Tweaks have to be installed in Dom0 to enable a compose key? Is there a sys-compose-key VM type of workaround? Are there known methods for enabling compose keys or easily typed accented letters?
Open the Applications menu (most left Q in the task bar), choose System Tools > Keyboard.
In the Keyboard opened window, select the Layout tab, deselect the Use system defaults checkbox. Then in the Compose key field, choose your wanted compose key (example: Caps Lock, Right Win, Scroll Lock, …).
The change will be available only after a session restart.
