I am currently trying to recreate my workflow using salt.
for example, this is my pwmanager.sls in /srv/user_salt:
{% if grains['id'] == 'dom0' %}
template-pwmanager--create-template:
qvm.clonse:
- name: template-pwmanager
- source: fedora-40-minimal
- class: TemplateVM
pwmanager-create-app-qube:
qvm.vm:
- name: q-pwmanager
- present:
- template: template-pwmanager
- labels: black
- prefs:
- label: black
- features:
- menu-items: org.keepassxc.KeepassXC.desktop
- require:
- qvm: template-pwmanager
{% elif grains['id'] == 'template-pwmanager' %}
template-pwmanager-install-apps-in-template:
pkg.installed:
- neovim
- keepassxc
{% endif %}
/srv/user_salt/top.sls:
user:
dom0 or template-pwmanager:
- pwmanager
If i run sudo qubesctl --show-output state.highstate for the first time, i get the error:
local:
Function: qvm.clonse
Comment: State 'qvm.clone' was not found in SLS 'pwmanager' Reason: 'qvm.clone' is not available
(pwmanager--create-app-qube also fails because of this, i thik this is not important because it just says that the requiesite failed and i dont want to type so much)
if i run the second time sudo qubesctl --show-output state.highstate without changing anything, it correctly creates template-pwmanager and the q-pwmanager. But the error occurs always, so i always have to run it twice. This also happpens if i run sudo qubesctl --targets=template-pwmanager --show-output state.highstate the first time. If I run sudo qubesctl --targets=template-pwmanager --show-output state.highstate again, then all 3 succeed, then disp-mgmt-template-pwmanager starts, which starts template-manager, which also succeeds - but it doesn’t install anything. The summary shows that 0 succeeded and 0 failed.
