I use tuta as my email provider. They do not provide a .deb application. Only AppImage.
Its daunting to log into my account 3-5 times a day every day. So i decided to create an appVM, make it disposable and launch the AppImage inside. This way i can stay logged in throughout sessions.
However, when i try to login, it says ‘cannot reach our servers’ but when i open brave or firefox im able to access internet
Try running it with “qvm-run -p AppVM /path/to/appname” to watch for any error messages on startup going to the console. If the app has command parameters for verbose settings add those here as well.
Try with “-u root” to see if that is some kind of default permissions problem opening a socket or something. Don’t run it normally this way though, just as a test.
If there is still no indication of the specific error then try ruining it under “strace” control. Strace will follow the execution of the app through the startup sequences and display all system call return codes so you can see what specific system call(s) is actually failing. Then go back in that stream and find what parameters were sent to that system call. It might be missing or invalid data being sent causing the failure.
I have tried ‘qvm-run -p tuta /home/user/tutanota-desktop-linux.AppImage’ And with -u root. AppImage still fails to connect to tuta servers. Also, this is on the appvm. Not a disposable. Firefox still works. Please see the results.
[0401/145551.084954:FATAL:electron_main_delegate.cc(295)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
/bin/bash: line 1: 1473 Trace/breakpoint trap (core dumped) /home/user/tutanota-desktop-linux.AppImage
[admin@dom0 ~]$ qvm-run -p tuta /home/user/tutanota-desktop-linux.AppImage
the monkey has been patched pid: 1559
(node:1559) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(Use `tutanota-desktop --trace-deprecation ...` to show where the warning was created)
[1559:0401/145615.494579:ERROR:browser_main_loop.cc(278)] Gdk: gdk_atom_intern: assertion 'atom_name != NULL' failed
[1559:0401/145615.495267:ERROR:browser_main_loop.cc(278)] Gdk: gdk_atom_intern: assertion 'atom_name != NULL' failed
version: 220.240321.0
resolving key... tutanota-vault
config up to date
[2024-04-01T13:56:15.813Z] using safeStorage with backend gnome_libsecret
[2024-04-01T13:56:15.934Z] Create tray:true
[DesktopSseClient] Resetting stored state
[DesktopSseClient] sseInfo corrupted or not present, making sure pushEncSessionKeys and scheduled alarms are cleared
[ApplicationWindow] webAssetsPath: /tmp/.mount_tutanogKjNwy/resources/app.asar
MESA: error: ZINK: failed to choose pdev
glx: failed to create drisw screen
failed to load driver: zink
[ApplicationWindow] getting dictionaries from: https://app.tuta.com/desktop/dictionaries/
[1598:0401/145616.077534:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
default mailto handler: false
Webapp ready
[2024-04-01T13:56:16.087Z] [ElectronUpdater] INFO: Checking for update
[2024-04-01T13:56:16.088Z] [ElectronUpdater] INFO: checking-for-update
[ApplicationWindow] spellcheck-dictionary-initialized en-US
[1559:0401/145616.119053:ERROR:browser_main_loop.cc(278)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
desktop file exists, checking version...
[DesktopWindowManager] invalidating alarms for all windows
[DesktopWindowManager] invalidating alarms for window 1
[1642:0401/145616.452845:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
[1639:0401/145616.614980:ERROR:command_buffer_proxy_impl.cc(131)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[1559:0401/145616.655796:ERROR:browser_main_loop.cc(278)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
[1559:0401/145616.706854:ERROR:browser_main_loop.cc(278)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
[DesktopSseClient] scheduling to check sse in 1 seconds
[2024-04-01T13:56:17.740Z] [ElectronUpdater] INFO: Update for version 220.240321.0 is not available (latest version: 220.240321.0, downgrade is disallowed).
[2024-04-01T13:56:17.740Z] [ElectronUpdater] INFO: update not available: {
version: '220.240321.0',
files: [
url: 'tutanota-desktop-linux.AppImage',
sha512: 'fQsRj3326oQEBZmXaYgd2td/RYSagZhLQ04Z4zKCexIg+EyNYJ67W9e8zPbng6VrK9wtRie1R3lhJmJvYfKomA==',
blockMapSize: 130135
path: 'tutanota-desktop-linux.AppImage',
releaseDate: '2024-03-21T11:21:42.588Z',
signature: 'OAlLU+HizvQaEOjXp2l6JS2YN8U1RvFRD8xLqLzlLaeqIFxvn3QxZxjy77PFbkYVl1osSXi9S9Be5jLfQxhFX+eCah1C0nS7yORWS3H+4iNVRmAeAcCqx5WIaPLaFkfQUDzjyJAzbq6cHhCnkrKooJ7nzI4psj0VXhshdtz/nj/IDfNknp6YfAmtpBjlEc1EaGQPyfcVobpFNH9tPx33Y5BrAVcCJlofEGmggZ6mtpA6aWKOB7z66L57KQS2aTkVeCFRrF7mSPw+imK1H3ph4iAAYu5lzoc4J35VLb1xVjR+qNceskXT+AFnY/xzRA2iImin6fKTT4DmAu/I3sjXtA=='
[DesktopSseClient] scheduling to check sse in 10 seconds
[DesktopSseClient] sse info not available, skip reconnect
[ProtocolProxy] error for GET https://app.tuta.com/rest/sys/saltservice:
[ProtocolProxy] TypeError: fetch failed
at /tmp/.mount_tutanogKjNwy/resources/app.asar/desktop/DesktopMain.js:10:29050
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async /tmp/.mount_tutanogKjNwy/resources/app.asar/desktop/DesktopMain.js:10:29558
at async AsyncFunction.<anonymous> (node:electron/js2c/browser_init:2:47442) {
[cause]: AggregateError
at internalConnectMultiple (node:net:1114:18)
at internalConnectMultiple (node:net:1177:5)
at Timeout.internalConnectMultipleTimeout (node:net:1687:3)
at listOnTimeout (node:internal/timers:575:11)
at process.processTimers (node:internal/timers:514:7) {
code: 'ETIMEDOUT',
[errors]: [ [Error], [Error] ]
[ProtocolProxy] {"name":"TypeError","message":"fetch failed","stack":"TypeError: fetch failed\n at /tmp/.mount_tutanogKjNwy/resources/app.asar/desktop/DesktopMain.js:10:29050\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async /tmp/.mount_tutanogKjNwy/resources/app.asar/desktop/DesktopMain.js:10:29558\n at async AsyncFunction.<anonymous> (node:electron/js2c/browser_init:2:47442)"}
[ProtocolProxy] failed after 307ms
[1559:0401/145640.840528:ERROR:browser_main_loop.cc(278)] Gtk: gtk_widget_add_accelerator: assertion 'GTK_IS_ACCEL_GROUP (accel_group)' failed
im having this issue again. What i did last time to fix it hasnt been working. Idk if its fedora or debian update that broke it but the appimage cannot connect to the internet again. The appvm can connect to the internet, its just the appimage
i tried an older version of the appimage and still not working.
