I’ve ran into this issue a few times, and still can’t isolate the cause.
I install snapd and Qubes snap helper in the template.
I then install the snap package in the app vm.
In the app vm->terminal->snap list: Shows core18, core20, Joplin as broken.
- I removed Joplin, refresh core18 & core20 to the edge channel.
- Re-install Joplin.
- Terminal->snap list: Shows Joplin, no longer broken.
- Shut down the VM.
- Opened VM settings, and refresh applications.
While some snaps show, Joplin still doesn’t show as available applications.
Anyone know what’s going on?
