Fullscreen Firefox is frozen
Press F11 twice.
Firefox crashes
If you are facing frequent crashes or lags when using Firefox browser (especially when watching videos), you may need to turn off Hardware Acceleration. You can do this by navigating to “Preferences”, then “Performance”. Untick the “Use recommended performance settings” checkbox, followed by “Use hardware acceleration when available”.
If this doesn’t fix the issue, try turning off smooth scrolling by unticking “Use smoothing scrolling” under the “Browsing” section.
LibreOffice lags / 100% CPU usage
See 100% cpu with every scroll in LibreOffice
LibreOffice open as a tiny window
Some programs like LibreOffice open as a tiny window – small enough that the content of the file is not even visible.
You can open LibreOffice as a larger window using this workaround:
Using the command line
In the VM where you want to open the LibreOffice, open the
registrymodifications.xcufile in an editor:sudo nano ~/.config/libreoffice/4/user/registrymodifications.xcu -
Find the lines containing
ooSetupFactoryWindowAttributes. It will look like this:<item oor:path="/org.openoffice.Setup/Office/Factories/org.openoffice.Setup:Factory['com.sun.star.sheet.SpreadsheetDocument']"><prop oor:name="ooSetupFactoryWindowAttributes" oor:op="fuse"><value>61,61,1807,982;5;38,56,1807,982;</value></prop></item> -
We are interested in the values between the
<value>tag. These window position values are specified as:x-pos,y-pos,width,height ; window-state ; maximized-x-pos,maximized-y-pos,maximized-width,maximized-height. Edit the third and fourth values to your desired width and height (for example, to 1800 and 900). -
Do this once for every template and the program will always open at this size.
Using the GUI
- Open any Libreoffice app.
- Navigate to the “Tools” menu, select “Options”, then “Advanced”. Click the “Open Expert Configuration” button.
- Search for “ooSetupFactoryWindowAttributes”.
- Scroll right to see the values set for each component as a string value. For example:
61,61,1807,982;5;38,56,1807,982;. These window position values are specified as:x-pos,y-pos,width,height ; window-state ; maximized-x-pos,maximized-y-pos,maximized-width,maximized-height. Edit the third and fourth values to your desired width and height (for example, to 1800 and 900). - Do this once for every template and the program will always open at this size.
- Page archive
- First commit: 08 Dec 2020. Last commit: 08 Dec 2020.
- Applicable Qubes OS releases based on commit dates and supported releases: 4.0
- Original author(s) (GitHub usernames):
- Original author(s) (forum usernames):
- Document license: CC BY 4.0
