I am attempting to update dom0, but I keep running into this error:
_[?25h'/usr/lib/qubes/qrexec-client-vm dom0 qubes.ReceiveUpdates /usr/lib/qubes/qfile-agent /var/lib/qubes/dom0-updates/packages/*.rpm' failed with exit code 1!
I did a search, and other topics said that it was a storage error. So I increased dom0’s size to 40gb. My updatevm, sys-firewall has 12gb free. However, that did not fix the error. I also tried using sys-net as the ubdatevm to no luck, as well as increasing max ram. Also no luck. Does anyone know if there is something else I should be trying?
