This is the output: --2026-02-10 19:22:25-- https://updates.signal.org/desktop/apt/keys.asc Resolving updates.signal.org (updates.signal.org)... failed: Non-recoverable failure in name resolution. wget: unable to resolve host address ‘updates.signal.org’ gpg: no valid OpenPGP data found. zsh: exit 4 wget -O- https://updates.signal.org/desktop/apt/keys.asc | zsh: exit 2 gpg --dearmor > signal-desktop-keyring.gpg
Before, someone said to do use curl instead - I believe this worked before.
curl -sx 127.0.0.1:8082 https://updates.signal.org/desktop/apt/keys.asc | gpg --dearmor | sudo tee -a /usr/share/keyrings/signal-desktop-keyring.gpg > /dev/null
When I run this, I get this message:
WARNING: Tor proxy doesn't seem to be functional. Stream isolation will be disabled.
I don’t believe this happened before.
I try to move on to #2 , and replace wget with curl.
curl -sx 127.0.0.1:8082 signal-desktop.sources https://updates.signal.org/static/desktop/apt/signal-desktop.sources;
cat signal-desktop.sources | sudo tee /etc/apt/sources.list.d/signal-desktop.sources > /dev/null
Types: deb
URIs: https://updates.signal.org/desktop/apt
Suites: xenial
Components: main
Architectures: amd64
Signed-By: /usr/share/keyrings/signal-desktop-keyring.gpg
Then finally I try to run the last command, to install, and get this error:
It is very simple. Start your templateVM in SYSMAINT mode (advanced settings//kernel boot mode SYSMAINT). Start Terminal and install wget sudo apt install wget. Then export https_proxy=127.0.0.1:8082. Afterwards just follow the instructions on the signal web page https://signal.org/download/# :
# NOTE: These instructions only work for 64-bit Debian-based
# Linux distributions such as Ubuntu, Mint etc.
# 1. Install our official public software signing key:
wget -O- https://updates.signal.org/desktop/apt/keys.asc | gpg --dearmor > signal-desktop-keyring.gpg;
cat signal-desktop-keyring.gpg | sudo tee /usr/share/keyrings/signal-desktop-keyring.gpg > /dev/null
# 2. Add our repository to your list of repositories:
wget -O signal-desktop.sources https://updates.signal.org/static/desktop/apt/signal-desktop.sources;
# 3. Update your package database and install Signal:
sudo apt update && sudo apt install signal-desktop
Afterwards create an appVM, connect it to your whonix gateway and fire up your SIGNAL-Desktop. Works out of the box…
