I’ve tried for a few days now, to try to install 2.4.1 but time and time again it just keeps crashing or freezing
I’ve only been able to boot inside the operating system once, when it failed was when I went to go to leave for moment in which the OS locks its self, the entire system was inaccessible past that point.
Just to get to that point. I had to go through countless freezes of the installers where the installer would crash before it could get the Fedora Gui.
I tried again to try and install this morning but no no success. I’ve used rufus and dd in a linux terminal and same exact problems.
It would freeze after after the qubes configuration Gui is finished and then is switch then to the TTY. Prompting me a to reboot to see if maybe I had to only to get to the LUKS screen enter a password and stay stuck there.
The Qubes OS recovery is completely void aswell, with a response of no “linux install”
To go even further, I made sure to use all 3 of my flash drives to make sure it wasn’t just a faulty usb to once again no avail. Ive tried all the options on the grub bootloader aswell and still same problems
Its very confusing to me because I’ve never had these issues before with any other qubes os version.
Could there be any reason why this at all is happening?.
And if so what do I do?
