After installing Skulls, sys-net won’t start, seems to be a problem with the pci device. What is the solution?
I am probably not the person to help you. .
Still, to be more likely to get a reply, please describe your hardware… Also any other symptoms you see.
I take it that you installed Skulls after you had Qubes installed and working?
Perhaps consider backing up what ever is on computer that is important to you.
network device is dissapers. but i can fixed. thank you
