Trezor setting up - pip3 instalation - Whonix AppVM
Hello to all,
I am new to Qubes and linux, I have followed Trezor instructions.
Thank you for your help in advance.
I have found similar issue, but on debian. Not clear to me, why I have this error even i should not have (If I understand correctly - quote DVM “Fedora doesn’t have PEP 668 enforced last time I checked. If you think it’s easier for you to use, then you can try it.” )
: Installing via python: pip3 externally managed environment - #2 by DVM
And How to fix it.
[workstation user ~]% pip3 install --user trezor
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.11/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
zsh: exit 1 pip3 install --user trezor
