TrenchBoot Anti Evil Maid for Qubes OS
Editor’s note: The following is a guest post by Michal Zygowski from 3mdeb on the work they’ve been doing to upgrade Anti Evil Maid (AEM). The original post can be found on the 3mdeb blog. This work was made possible through generous donations from the Qubes community via OpenCollective. We are immensely grateful to the Qubes community for your continued support and to 3mdeb for contributing this valuable work.
Abstract
Qubes OS Anti Evil Maid (AEM) software heavily depends on the availability of the DRTM technologies to prevent the Evil Maid attacks. However, the project has not evolved much since the beginning of 2018 and froze on the support of TPM 1.2 with Intel TXT in legacy boot mode (BIOS). In the post we show how existing solution can be replaced with TrenchBoot and how one can install it on the Qubes OS. Also the post will also briefly explain how TrenchBoot opens the door for future TPM 2.0 and UEFI support for AEM.
Introduction
As Qubes OS users, promoters, and developers, we understand how essential it is to be aware of the latest developments in maintaining the security of your favorite operating system. We’re excited to share our plans to integrate the TrenchBoot Project into Qubes OS’s new Anti-Evil Maid (AEM) implementation. As you may know, traditional firmware security measures like UEFI Secure Boot and measured boot, even with a Static Root of Trust (SRT), may only sometimes be enough to ensure a completely secure environment for your operating system. Compromised firmware may allow for the injection of malicious software into your system, making it difficult to detect. To overcome these limitations, many silicon vendors have started implementing Dynamic Root of Trust (DRT) technologies to establish a secure environment for operating system launch and integrity measurements. We’re excited to take advantage of these advancements through integration with the TrenchBoot Project.
The usage of DRT technologies like Intel Trusted Execution Technology (TXT) or AMD Secure Startup is becoming more and more significant; for example, Dynamic Root of Trust for Measurement (DRTM) requirements of Microsoft Secured Core PCs. DRTM has yet to find its place in open-source projects, but that gradually changes. The demand for having firmware-independent Roots of Trust is increasing, and projects that satisfy this demand are growing TrenchBoot is a framework that allows individuals and projects to build security engines to perform launch integrity actions for their systems. The framework builds upon Boot Integrity Technologies (BITs) that establish one or more Roots of Trust (RoT) from which a degree of confidence that integrity actions were not subverted.
Qubes OS Anti Evil Maid (AEM) software heavily depends on the availability of DRTM technologies to prevent Evil Maid attacks. However, the project hasn’t evolved much since the beginning of 2018 and froze on the support of TPM 1.2 with Intel TXT in legacy boot mode (BIOS). Because of that, the usage of this security software is effectively limited to older Intel machines only. TPM 1.2 implemented SHA1 hashing algorithm, which is nowadays considered weak in the era of forever-increasing computer performance and quantum computing. The solution to this problem comes with a newer TPM 2.0 with more agile cryptographic algorithms and SHA256 implementation by default.
The post will present the TrenchBoot solution for Qubes OS AEM replacing the current TPM 1.2 and Intel TXT-only implementation. The advantage of TrenchBoot solution over existing Trusted Boot is the easier future integration of AMD platform support, as well as TPM 2.0 and UEFI mode support.
Before we dive into the technical details, it is important to highlight that this achievement was made possible through the generous contributions of Qubes OS community via OpenCollective. We would like to express our gratitude and extend a special thank you to all who have supported our favourite operating system. To continue supporting Qubes OS, please consider donating through OpenCollective page. Thank you for your continued support!
Modificationts to original Qubes OS AEM
To replace the original implementation of Qubes OS AE there weren’t any AEM scripts modifications necessary. What actually had to change is GRUB and Xen Hypervisor (and Trusted Boot - to be removed). Why? one may ask… First of all, one must understand the role of a Trusted Boot (TBOOT).
Trusted Boot DRTM flow
Breakout of measured launch details
(Source: A Practical Guide to TPM 2.0)
The main role of Trusted Boot was to prepare a platform to be launched with Intel TXT (Intel’s DRTM technology) in an operating system agnostic way. It has been achieved by loading a tboot kernel with Multiboot protocol and the other system components as the modules. That way, TBOOT is the main kernel that starts first and prepares the platform for TXT launch. When the platform is ready, then tboot performs the TXT launch. The control is passed to SINIT Authenticated Code Module (ACM), a binary signed and provided by Intel designed for DRTM technology. SINIT ACM uses TXT to measure the operating system components in a secure manner. Then the control is handed back to the tboot kernel, which checks if the operation was successful and boots the target operating system.
Although the tboot tried to be as OS agnostic as possible, some tboot presence awareness from the operating system is needed because the application processor cores (all cores except the main one) are left in a special state after TXT launch and cannot be woken up like in traditional boot process. To solve this problem, tboot installs a special processor wakeup procedure in the memory, which OS must call into to start the processor cores. Only then OS may initialize the processor per its own requirements.
As one can see, the process is complex in the case of Intel TXT. Migration of all tboot responsibilities was not trivial and has been divided into the work on both GRUB and Xen Hypervisor side of Qubes OS.
GRUB modifications
GRUB logo
In order to fulfill the same role as tboot, GRUB had to learn how to prepare the platform and perform the TXT launch. Most of the work for that particular part has been done by Oracle Team working on TrenchBoot for GRUB. That work, however, covered the Linux kernel TXT launch only. What still had to be done was the Multiboot2 protocol support in GRUB to be able to TXT launch a Xen Hypervisor. The patches have been prepared for the respective Qubes GRUB package.
Xen modifications
Xen Project logo
Analogically to GRUB, Xen had to take over some responsibilities from tboot. Due to the Intel TXT requirements for the boot process, a new entry point had to be developed to which SINIT ACM will return control. The new entry point was responsible for saving information that a TXT launch happened and cleaning up the processor state so that the booting of the Xen kernel could continue with the standard Multiboot2 path. Among others, if Xen detected TXT launch, it had to perform the special processor cores wakeup process (which has been rewritten from TrenchBoot Linux patches to Xen native code) and measure external components before using them (that is the Xen parameters, Dom0 Linux kernel, initrd and Dom0 parameters). Xen also had to reserve the memory regions used by Intel TXT, as when tboot was used. The relevant source code for the respective Qubes Xen package is available here.
Installation and verification of TrenchBoot AEM on Qubes OS
For a seamless deployment and installation of TrenchBoot AEM, the modifications Qubes OS components compilation. Those patches have been presented earlier with have been converted to patches which are applied to projects’ sources during links to Pull Requests. It allows building ready-to-use RPM packages that can be installed directly on an installed Qubes OS system. The pre-built packages can be downloaded from here. The packages have been covered with SHA512 sums signed with 3mdeb’s Qubes OS TrenchBoot AEM open-source software release 0.x signing key available on 3mdeb-secpack repository. To verify the RPM packages, fetch the key with the following command: gpg --fetch https://raw.githubusercontent.com/3mdeb/3mdeb-secpack/master/open-source-software/qubes-os-trenchboot-aem-open-source-software-release-0.x-signing-key.asc and then to verify the packages, please run:
$ gpg --verify sha512sums.sig sha512sums
gpg: Signature made wto, 31 sty 2023, 11:06:06 CET
gpg:                using RSA key 3405D1E4509CD18A3EA762245D289020C07114F3
gpg: Good signature from "Qubes OS TrenchBoot AEM open-source software release 0.x signing key" [unknown]
gpg: WARNING: This key is not certified with a trusted signature!
gpg:          There is no indication that the signature belongs to the owner.
Primary key fingerprint: 3405 D1E4 509C D18A 3EA7  6224 5D28 9020 C071 14F3
$ sha512sum -c sha512sums
grub2-common-2.06-1.fc32.noarch.rpm: OK
grub2-tools-extra-2.06-1.fc32.x86_64.rpm: OK
xen-licenses-4.17.0-3.fc32.x86_64.rpm: OK
grub2-pc-2.06-1.fc32.x86_64.rpm: OK
xen-libs-4.17.0-3.fc32.x86_64.rpm: OK
grub2-tools-2.06-1.fc32.x86_64.rpm: OK
xen-hypervisor-4.17.0-3.fc32.x86_64.rpm: OK
grub2-pc-modules-2.06-1.fc32.noarch.rpm: OK
xen-runtime-4.17.0-3.fc32.x86_64.rpm: OK
grub2-tools-minimal-2.06-1.fc32.x86_64.rpm: OK
python3-xen-4.17.0-3.fc32.x86_64.rpm: OK
Check if GPG returns a good signature and if yes, check if the RPM checksum matches. All files must be in the same directory for the procedure to work.
Note, in order to use the TrenchBoot AEM for Qubes OS, you have to own a TXT-capable platform with TXT-enabled firmware offering legacy boot. Such platform can be Dell OptiPlex 7010. You can visit Dasharo with Intel TXT support blog post to learn more about such hardware and firmware. If you want to get OptiPlex with Dasharo pre-installed, you can get one from 3mdeb shop.
Building Xen and GRUB packages
If you are not interested in compilation, skip to the next section.
To not make the post excessively long, the procedure for building packages has been put into TrenchBoot SDK documentation. Follow the instructions in the file to build the TrenchBoot AEM packages.
Installing Xen and GRUB packages
The following process was carried out and tested on Qubes OS 4.2.
In order to install the packages one has to send the Xen and GRUB RPMs to the Dom0. Please note that moving any external files or data to Dom0 is potentially dangerous. Ensure that your environment is safe and the RPMs have the right checksums after copying them to Dom0. If you don’t know how to copy files to Dom0, refer to the Qubes OS documentation.
  1. Even before installing packages, it is required to enable the current-testing repository to avoid the need to install additional dependencies:
     sudo qubes-dom0-update --enablerepo=qubes-dom0-current-testing
  2. If the RPMs are inside Dom0, install them with the following command (assuming you downloaded all of them to one directory):
     sudo dnf update \
         python3-xen-4.17.0-3.fc32.x86_64.rpm \
         xen-hypervisor-4.17.0-3.fc32.x86_64.rpm \
         xen-libs-4.17.0-3.fc32.x86_64.rpm \
         xen-licenses-4.17.0-3.fc32.x86_64.rpm \
         xen-runtime-4.17.0-3.fc32.x86_64.rpm \
         grub2-common-2.06-1.fc32.noarch.rpm \
         grub2-pc-modules-2.06-1.fc32.noarch.rpm \
         grub2-pc-2.06-1.fc32.x86_64.rpm \
         grub2-tools-2.06-1.fc32.x86_64.rpm \
         grub2-tools-extra-2.06-1.fc32.x86_64.rpm \
  3. Invoke sudo grub2-install /dev/sdX, where X is the letter representing the disk with /boot partition.
  4. Additionally, you will have to download SINIT ACM and place it in /boot partition/directory so that GRUB will be able to pick it up. Note it is only necessary if your firmware/BIOS does not include/place SINIT ACM in the Intel TXT region. You may obtain all SINIT ACMs as described here. Copy the SINIT ACM suitable for your platform to /boot directory. In the case of Dell OptiPlex it will be SNB_IVB_SINIT_20190708_PW.bin.
  5. Install Qubes AEM packages with the following command because Qubes OS 4.2 lacks AEM packages:
     qubes-dom0-update  --enablerepo=qubes-dom0-current-testing anti-evil-maid
  6. Enter the SeaBIOS TPM menu (hotkey t) and choose the clear TPM option. Then activate and enable the TPM by selecting the appropriate options. If in any case you are using proprietary firmware, clear the TPM and then enable and activate it in the firmware setup application.
  7. Follow the steps in set up TPM for AEM.
  8. The anti-evil-maid script may not work with LUKS2 in its current state, so make a fix according to this Pull Request if needed.
  9. Now it is possible to setup Qubes OS AEM device. This will create the AEM entry in Qubes GRUB, but this entry is using tboot.
  10. You will need to edit the grub configuration file (/boot/grub2/grub.cfg) by copying the standard Qubes OS entry (without AEM) and adding:
    slaunch
    slaunch_module /
    before the multiboot2 directive, which loads Xen Hypervisor. Name the entry differently, e.g. Qubes OS with TrenchBoot AEM. Also, you will need to copy the AEM parameters for the Linux kernel: e.g.:
    aem.uuid=38474da6-7b2d-410d-95e6-8683005fb23f rd.luks.key=/tmp/aem-keyfile rd.luks.crypttab=no
    We are still working on automating this step, so please bear with the manual file edition for now.
Example GRUB entry:
menuentry 'Qubes, with TrenchBoot AEM' --class qubes --class gnu-linux --class gnu --class os --class xen $menuentry_id_option 'xen-gnulinux-simple-/dev/mapper/qubes_dom0-root' {
        insmod part_msdos
        insmod ext2
        set root='hd0,msdos1'
        if [ x$feature_platform_search_hint = xy ]; then
          search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 --hint='hd0,msdos1'  38474da6-7b2d-410d-95e6-8683005fb23f
        else
          search --no-floppy --fs-uuid --set=root 38474da6-7b2d-410d-95e6-8683005fb23f
        fi
        echo    'Loading Xen 4.17.0 ...'
        if [ "$grub_platform" = "pc" -o "$grub_platform" = "" ]; then
            xen_rm_opts=
        else
            xen_rm_opts="no-real-mode edd=off"
        fi
        slaunch
        slaunch_module  /SNB_IVB_SINIT_20190708_PW.bin
        multiboot2      /xen-4.17.0.gz placeholder  console=none dom0_mem=min:1024M dom0_mem=max:4096M ucode=scan smt=off gnttab_max_frames=2048 gnttab_max_maptrack_frames=4096 ${xen_rm_opts}
        echo    'Loading Linux 5.15.81-1.fc32.qubes.x86_64 ...'
        module  /vmlinuz-5.15.81-1.fc32.qubes.x86_64 placeholder root=/dev/mapper/qubes_dom0-root ro rd.luks.uuid=luks-f1f850fa-59bf-4911-8256-4986c485e112 rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap i915.alpha_support=1 rd.driver.pre=btrfs rhgb quiet console=ttyS0,115200  aem.uuid=38474da6-7b2d-410d-95e6-8683005fb23f rd.luks.key=/tmp/aem-keyfile rd.luks.crypttab=no
        echo    'Loading initial ramdisk ...'
        module2 --nounzip   /initramfs-5.15.81-1.fc32.qubes.x86_64.img
You may put the above entry to /etc/grub.d/40_custom to avoid the removal of the TrenchBoot AEM entry in case grub2-mkconfig will be called to overwrite grub.cfg. Please note such a workaround will not allow for automatic Xen, Linux, and initrd updates which may include security fixes. Making the grub.cfg seamless for TrenchBoot is still in progress.
Verifying TrenchBoot AEM for Qubes OS
The moment of truth has come. If the installation has been performed successfully, it is time to try out the TXT launch. So reboot the platform and choose the newly created entry with TrenchBoot. If it succeeds, you should get a TPM SRK and LUKS password prompts.
After the system boots, one may check if DRTM PCRs (17 and 18, 19 is not used by TrenchBoot for now) have been populated:
cat /sys/class/tpm/tpm0/pcrs
PCR-00: 3A 3F 78 0F 11 A4 B4 99 69 FC AA 80 CD 6E 39 57 C3 3B 22 75
PCR-01: 4D E4 B0 42 71 50 E4 B1 DE C0 D7 F1 A0 29 A2 65 11 30 72 FD
PCR-02: CE EA EC 0A 01 D5 7B A3 55 5A 4C 02 59 4A EE A1 C9 41 78 FB
PCR-03: 3A 3F 78 0F 11 A4 B4 99 69 FC AA 80 CD 6E 39 57 C3 3B 22 75
PCR-04: 01 7A 3D E8 2F 4A 1B 77 FC 33 A9 03 FE F6 AD 27 EE 92 BE 04
PCR-05: BF 4E 38 B0 A7 7A 7A 4D 1A A9 B5 0F 59 D8 E5 F7 A6 46 8E 48
PCR-06: 3A 3F 78 0F 11 A4 B4 99 69 FC AA 80 CD 6E 39 57 C3 3B 22 75
PCR-07: 3A 3F 78 0F 11 A4 B4 99 69 FC AA 80 CD 6E 39 57 C3 3B 22 75
PCR-08: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-09: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-10: 9A 51 66 4D EB 1C B9 72 91 87 59 C4 89 AC 9A FF 7F 10 BF B3
PCR-11: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-12: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-13: 10 78 D0 16 8C 85 85 3A 7E 0A A1 D7 56 02 A7 05 D4 7F 22 64
PCR-14: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-15: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-16: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-17: 2A C9 64 F2 E2 96 50 B3 1D B7 2F 77 C4 7C A6 5D AA C8 4E E7
PCR-18: 84 4D D5 8D 95 EB 96 F6 CE 92 51 9C FD E2 33 45 71 C3 87 92
PCR-19: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-21: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-22: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCR-23: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Note that AEM will fail to unseal secrets as the PCRs are changed. To re-seal the secret you will have to perform the following steps after a successful boot with TrenchBoot:
  1. Re-seal the secret sudo anti-evil-maid-seal "".
  2. Reboot the machine and notice that the anti-evil-maid service no longer fails during boot. The secret should be displayed on the screen, indicating the machine boots correctly and unseals the secret.
Summary
It has been shown that TrenchBoot can be integrated to perform DRTM secure launch of Qubes OS in place of old tboot. Moreover, TrenchBoot is more extensible to other platforms like AMD. In the future, Anti Evil Maid will be available on both Intel and AMD platforms with both TPM 1.2 and TPM 2.0, thanks to TrenchBoot (which seemed to not be possible with tboot only).
If you think we can help in improving the security of your firmware or you are looking for someone who can boost your product by leveraging advanced features of used hardware platform, feel free to book a call with us or drop us email to contact3mdebcom. If you are interested in similar content, feel free to sign up to our newsletter
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2023/01/31/trenchboot-aem-for-qubes-os/
Wish I saw this earlier. I ordered an old thinkpad a couple of days ago to install heads on. :sweat_smile:
With TXT being a requirement, I guess it means that it’s impossible to use with the Z690 motherboard running Dasharo firmware?
Good news! I see that the current instructions still mention Legacy boot, so in addition to AMD support, I hope that the future version will also support UEFI boot.
Regarding HEADS, can someone explain to me how the security of Trenchboot’s use of DTRM differs from HEADS and an idea of the pros & cons of either setup.
So HEADS uses a static root of trust with the TPM that holds the hashed values of /boot etc. in the PCR registers which it measures and checks on each boot.
What does a dynamic root of trust implementation offer that this doesn’t, and where does it fall short of HEADS in serving a particular threat model over another.
I’m reading in to DTRM but it will take me some time to wrap my head around it, and any explanation would be helpful. Thanks.
The whole description is so abstract that I do not get what it does.
SRTM is very different from DRTM. Please check our talks from OSFC and Qubes OS Summit:
Big thing is LKML patchset.
There are many advantages, but in short concept is simple (implementation more complex):
  • SRTM is as good as code making first measurement
  • code making first measurement have to be protected otherwise initial measurement can be faked (or replied) and whole set of measurements is broken (AEM attack can make it possible)
  • mechanisms for protection that code are very problematic (e.g. Intel Boot Guard)
  • most Heads installation do not protect bootblock, which makes first measurement
  • if you want to re-establish trust in SRTM you have to reboot, which in some situation should be avoided
  • DRTM by special CPU instruction has power of creating root of trust dynamically at “any” point in time when special instruction is called, what DRTM does is making sure whole hardware is in clean state (arguably less state, smaller TCB since we “get rid” of firmware)
So DRTM is big hope for platforms with black box proprietary BIOS. For platforms with open-source firmware like Heads DRTM can largely extend security and bring new value e.g. recovery without physical SPI interaction in case of infection, runtime protection, attestation, dynamically launched environment for administrative and other sensitive work. SRTM cannot provide that because its work ends after passing control to OS (in case of Heads, there is IMA, but I’m not sure anyone in Qubes OS use it, also even SRTM+IMA cannot provide the same measures of security which DRTM provides). So setup that connects SRTM+DRTM+attestation are best things of two worlds.
One more thing. No matter what we think about Microsoft, they put a lot of resources in securing their operating system and trying to make it better then the others.
DRTM is foundation technology for System Guard 1, 2, 3. If we believe in open-source superiority we need competing open solution to what System Guard does. TrenchBoot is the only project which can provide that at this point.
Great response. Thanks. The resources you linked were helpful, although it will still take some time for me to properly grasp it all.
So in the case of D-RTM is the root of trust the trusted launch from CPU? The concept of the trust chain is great and makes sense why it would be advantageous over the S-RTM.
In HEADS there is the external validation of HEADS itself with the Hardware Token ensuring HEADS code is signed (I believe). Is there something special about the trusted launch from CPU that means we can have good trust initially that answers the question that the HOTP answers for HEADS?
For a non-technical user this is simple to understand with HEADS, where the hardware token verifies HEADS integrity to me, and HEADS then measures and verifies the intergrity of the stack with the hashed values in PCR registers. I’m curious how D-RTM answers that.
This question may be confused and a result of my undeveloped understanding of DRTM, if so I apologize.
Also, to what degree does the current implementation for Qubes compare to HEADS in its security? Is it already there, or what is the rough developmental timeline for it?
Thank you.
@Insurgo I’d love to hear what your thoughts are on this and the place D-RTM could have in your work.
Some concepts are mixed in here.
Heads is a payload of coreboot, and coreboot is enabling measured boot.
As a result, coreboot in measured boot (platform dependent) will initialize the TPM as early as possible (bootblock/romstage) and measure its stage (bootblock) and then measure other stages of coreboot (romstage, ramstage etc) into PCR2. Those are called TPM extend operations. As a result of those measurements (XOR operations upon prior measurements) the TPM keeps in this PCR2 extended measurements resulting in final PCR2 hash. Then coreboot launches its measured payload. leaving a trace of its measurements into a log (TCPA log) that can be observed from Heads recovery shell (linux) by calling cbmem -L).
Then, while Heads payload boots, it measures different stuff in different PCRs as documented Keys and passwords in Heads | Heads - Wiki
The important part here is to differentiate measurements from secret sealing/unsealing which I dumped here for review prior of being added into the wiki: Distinction between TPM measurements and sealing/unsealing TPM operations · Issue #116 · osresearch/heads-wiki · GitHub
In short to address your comment above and the next:
Heads, upon firmware flashing/upgrade, will not be able to “unseal” its first secret (remote firmware integrity attestation) expected to be sealed into a distinct TPM NV memory region, which is expected to be the result of PRCs 0-4 previous sealed measurements… This is what was sealed and communicated to smartphone through Qr code (secret) scanned to generate TOTP on both phone and laptop. HOTP takes this secret and “seals” it into the USB Security dongle in a similar fashion with GPG admin PIN to store in there. This is the same secret, sealed inside of the TPM, which is used to unseal both TOTP code generation and to validate its integrity on the Nitrokey Pro/Nitrokey Storage/Librem Key upon challenge, resulting in green/red LED flashing and confirming “HOTP:Success” message on Heads main screen at each boot.
There is another “more advanced” sealed secret under Heads (Heads runtime state attestation), which is the consequence of the same prior PCRs (remote firmware integrity attestation), adding PCR 5-6-7 into the pool, but this time uses the TPM as a secret storage device, sealing those measurements (PCR 0-1-2-3-4-5-6-7) into TPM NV memory with a passphrase: this passphrase is used to unseal the Disk unlock key, added into the LUKS header when setting a new boot default, to be passed by Heads as the LUKS decryption key when booting a default boot option (through an additional cpio file applied on top of initramfs’ OS kernel to permit the OS to unlock disk without prompting user for the Disk Recovery Key passphrase). This TPM disk unlock key, that can be released only if all measurements are as when they were sealed, will release secret only if the passphrase can unseal that TPM memory region, with the same prior measurements that were taken when sealing the secret.
Now, and this is where some misinterpretation were done on what Heads does and doesn’t:
Heads is coreboot+linux payload in our scenario here. So PCR2 contains those measurements.
Then, really early in boot (init script calls cbfs-init), measurements of user’s gpg key material is measured inside of PCR7.
Heads creates digests of /boot files, and asks the user to detach sign its content.
When asked to setup a default boot option, it will also extract boot options (xen, kernel, boot options) and save those under /boot/kexec_* files, also detached signed with user’s private key from USB Security dongle (and GPG User PIN). On each boot, those detached signed digests are verified (integrity+authenticity) against that firmware injected, measured and extracted user’s public key prior of permitting to boot. Upon dom0 upgrade and reboot, Heads will see changes (new files, changed files, deleted files as compared to digest) and will ask the user to confirm knowledge of the changes by recreating new digests and detach signing them. When selecting default boot option that changed, the user is asked to enroll a new default boot option, and also has to detach sign that new configuration.
So on each boot, Heads:
  • Remote attests firmware integrity through TOTP+HOTP (coreboot + payload → PCR2)
  • Extract public key material from firmware (+measure into PC7) to be able to verify that /boot content is as expected (integrity+authenticity).
  • On-demand (per boot policy) needed kernel modules are measured (PCR5) prior of being loaded (usb modules in case of USB Security dongle to remote attest through HOTP)
  • If user needs to boot to USB thumb drive, usb storage and other needed kernel modules are measured and loaded (PCR5), invalidating possibility to do a default boot (measurement mismatch, impossible to unseal disk unlock key)
  • When booting default boot option with TPM disk unlock key unsealing, the LUKS header is measured against sealed value (PCR6), which TPM disk unlock key will not unseal if different
  • And of course, going into recovery console will invalidate measurements as well since PCR4 is extended, being part of TOTP/HOTP secret sealing/unsealing. So someone going into recovery will not be able to unseal any secret in that boot session.
Future (TXT and D-RTM)
As @pietrushnic noted, S-RTM and D-RTM are two different and complementary mechanisms of operations. S-RTM being useful for pre-boot integrity validation only, requiring to reboot to validate the integrity of the system, where D-RTM can be re-launched on demand.
To address specifics:
On above notes: it is currently impossible for ivy/sandy bridge (xx20/xx30 Lenovo Thinkpads x230/x220/t420/t430/t530/w530 Optiplex etc) to have bootblock measured in a totally trusted way, even with D-RTM on those platforms, but I would be really happy to be challenged wrong under WIP xx30: TXT support ? by tlaurion · Pull Request #1172 · osresearch/heads · GitHub. The reasoning is that sandy/ivy bridge cannot have bootblock under IBB and have ACM blob measure it to PCR0 from TXT.
Actually, there is no IBB definition possible for sandy/ivy bridge (xx20/xx30) based platforms; IBB + FIT descriptor only having happened under Haswell+ (which t440p could be interesting candidate) where the cpu cannot measure bootblock into PCR0 before haswell+.
A small PoC was attempted under WIP xx30: TXT support ? by tlaurion · Pull Request #1172 · osresearch/heads · GitHub for the x230.
The results were:
  • ACM blob + sINIT blobs (download+ extraction provided), enables TXT and bases for D-RTM (firmware enablement).
  • ivy bridge/sandy bridge, being pre-haswell, cannot include the bootblock as part of IBB (Haswell+ could have bootblock as part of IBB Measured Boot — coreboot 4.19-479-gdb0946239f documentation, not ivy bridge/sandy bridge)
So from my current understanding, D-RTM could be possible on ivy/sandy/haswell since TXT is possible there.
Questions are, for Heads:
  • Blobs redistribution problems for ACM blobs (totally possible as per WIP xx30: TXT support ? by tlaurion · Pull Request #1172 · osresearch/heads · GitHub for users to compile/have CircleCI stitch ROMs for end-users)
  • bootblock will not be measured by CPU ACM (into PCR0) but for haswell+ (t440p and newer Intel platforms, with additional blobs)
  • Heads relies on linux + kexec to boot into next linux kernel.
    • What changeset would need to be included into coreboot’s linux kernel to be slaunch compatible?
    • What changeset would need to be included into kexec to be able to chainload multiboot2 kernels? (Heads linux kernel → kexec → slaunch-> Xen → Qubes OS dom0 kernel(+initrd)
I hope this post answers both user needs and future collaborators.
I must +1 above quotes. Before telling us about some awesome new tech, we really need to understand what it is and why it’s better than what we already have.
I poked around on the TrenchBoot project website, but it wasn’t very enlightning. The explanations above are helpful, but I think they would be more helpful if added to the website’s FAQ section. I’ve created a ticket to address this:
