TPM Column in a HCL List
So I ran qubes-hcl-report -s vault in my dom0’s terminal.
In a terminal’s output I got
HVM: Active
I/O MMU: Active
HAP/SLAT: Yes
TPM: Device present
Remapping: yes
but in a .yml
hvm:
‘yes’
iommu:
‘yes’
slat:
‘yes’
tpm:
remap:
‘yes’
is generated. Can someone please explain what (exactly) does this mean? Is there any log with a more detailed info generated during the HCL report creating process?
Is this why TMP column in a HCL list is mostly empty, or with a value “unknown”? In which case this value is generated? When “yes” value will be generated?
I have searched through the forum but could find only info of a case in which .yml generates value “disabled” for TPM.
I hope this is the right category for this kind of discussion.
@Sven @deeplow ?
No idea but you can try to look at the source code to see if you spot what it means:
Thanks @deeplow.
I did my best but couldn’t conclude why for TPM: Device present in terminal, output in .yml is tpm: ’ '…
@enmus @deeplow the issue is down to the fact TPM variable gets populated to terminal but TPM_s is the variable that goes into the YAML. Ive created a pull request to fix it
Thanks @plexus
Ill have to do the PR later - i had not added my GPG key to that github account yet so ill resolve later on and link the new PR here. I have to go out now so itll be a while.
