I’m a beginner with qubes but want to learn. I hope my question has merit.
Currently I am looking for laptop and stumbled upon many newer configurations. Most of them have TPM 2.0. But I would need TPM 1.2 to achieve Anti-Evil-Maid. Right? Edit: I’ve found it out. Yes, TPM 1.2 is needed with Qubes 4.0. This feature-request github QubesOS/qubes-issues/issues/6015 mentions it.
So if the desired isn’t capable of downgrading to 1.2 it wouldn’t work right?
And specifically talking about Dell Laptops, I think this is the list where we can check TPM 1.2 support correct?
This reply came a bit late, but TPM 1.2 is the only TPM version that works with AEM. Modern machines with TPM 2.0 aren’t compatible. One solution is to get a desktop motherboard with AEM support and then go buy a TPM 1.2 module.
