If a user attempts to onionize sources for a Standalone Debian vm and uses Whonix GW as networking for that qube then the following error will occur
So a Standalone qube will have to use Firewall for its networking. Torsocks in the Standalone qube will then be able to update from the onionized sources.
But what if you want your Debian template onionized? There is not yet a template for Kicksecure which is a hardened distribution morphing of Debian approved of by Whonix. Whonix updates from onionized sources successfully through the Qubes Updater mechanism, correct? So there must be an additional series of steps that must be carried out in order to update templates from onionized sources through the Qubes Updater mechanism if not through a Standalone with sources edited, tor transport installed, and tor running through the Qubes Firewall qube.
Centos, related to Fedora, has at least one onionized source out of SE. It would be interesting to see how Fedora updates would turn out if they were onionized. In principle, there is no reason why dnf(5) or yum couldnt update from an onionserver just like apt can (pacman also has onionized sourcing as an option), is there? There also must be a reason why Fedora is not so interested in onionizing.
Since updating a template directly is discouraged because that makes Dom0 vulnerable, what is the best way to onion update an VM OS? An onionized Debian Standalone, for instance, will still derive from a non onionized Debian template.
