Touchpad stops working from time to time (mostly right after logging in)
Hello, guys. I have a bug or something. It happens not everytime but sometimes. Just right after logging in I find touchpad not working. Today it happened first time not after logging in but right in the middle of the work so I had to use emergency shutdown by long-pressing the power button, losing some data that I couldn’t save. At the same time keyboard is working in such cases. I can’t use mouse because the model I have is somehow not recognized by the OS. More over, the designer of the laptop probably was a degenerate and placed all two USB ports extremely close to each other so I just can’t use the modem and the mouse adapter in the same time. So I always used touchpad. It’s not that I expect that you fix this bug, but I expect more that you can suggest me some solution that discloses for me how to use the keyboard to control the cursor in such cases when the touchpad is dead. Is there a way? Or even a way to rivive the touchpad? Or only emergency shutdown?
For tech specs: laptop is HP 14s fq1014ur.
