I"m using Qubes OS 4.1 and have barely set anything customized up yet. It’s in its default settings mostly.
This is how my qube-manager looks like:
Now to my problem: whenever I try to install the tor browser in whonix workstation qube I’m unable to install tor browser with the following message:
INFO: Downloading Tor Browser...
INFO: Downloading...: https://www.torproject.org/dist/torbrowser/11.5/tor-browser-linux64-11.5_en-US.tar.xz
INFO: CURL_OUT_FILE: /var/cache/tb-binary/.cache/tb/files/tor-browser-linux64-11.5_en-US.tar.xz
94%
/usr/libexec/helper-scripts/curl-prgrs: line 269: 11187 Killed ( set +e; $CURL --trace-ascii "$tracefile" -s "$@"; curl_exit_code="$?"; echo "$curl_exit_code" > "$statusfile"; echo >> "$tracefile"; sync )
ERROR: Failed to download: https://www.torproject.org/dist/torbrowser/11.5/tor-browser-linux64-11.5_en-US.tar.xz
Possible reasons:
- The download server is down.
- File size exceeded (endless data attack triggered).
- Tor Browser Downloader (by Whonix developers) has been broken due to upstream changes.
Recommendations:
- Try again later. If the error persists it probably won't solve itself before the next update.
- Check News: https://www.whonix.org/wiki/Stay_Tuned
- Manually update: https://www.whonix.org/wiki/Tor_Browser/Manual_Download
(Debugging information: curl_status_message: [81] - [curl-scripts curl-prgs (not curl!) reports: Endless data attack triggered.])
user@host:~$
