EDIT: I found the solution on this post but I was wondering is the problem whonix or qubes os? For those people with the same issue and too lazy to read through all these, just use “sudo repository-dist --enable --repository stable” on whonix workstation template terminal and then problem should be fixed
ORIGINAL: Although I have no problem connecting to Tor browser and in fact updating it on the brwoser itself and doing a successful systemcheck with no issues, this is the error I keep getting for the Tor downloader (anon dist) on my qubes-whonix workstation template. For the record I made no changes to any of the templates.
ERROR: www…torproject.org could not be reached.
Possible reasons:
- www…Index of /torbrowser is down
- download location changed
Please check:
Start menu → System → systemcheck
or in Terminal: systemcheck
or in Terminal with debugging: systemcheck -v
If systemcheck reports no problems with internet activity and downloading Tor Browser keeps failing, please report a bug!
(Debugging information: curl_status_message: [91] - [Invalid SSL certificate status.])
