Just started using Qubes a while back and my Top panel just disappeared. Like the top thing with the menu and workspaces and stuff. It’s not visible any more.
When I right click and select panel from system tools it gives this error:
This has been discussed countless times here, so if you’ve had searched forum for the same term as your topic is titled, you’d find the solution in a matter of seconds, instead to wait someone to respond here.
