After I add a device to an AppVM, it doesn’t show up in the devices section of Thunar. I have to open the console and mount it manually. What can I do to fix this?
I believe the issue is that it is not detected as a device when running gio mount --list, devices which show up when running that command can be mounted in Thunar, but my device does not do that.
It is a normal block device with a file system on it.
Separate question, what can I do to automatically mount it when attached if no one can solve this issue?
