There will shortly be new builds for 4.1 of the Debian-11 template.
It would be really useful for 4.1 users to:
test the new template (I’ll let you know once it is available), and
test the upgrade path from Debian-10.
The build for 4.0 is broken, so a new template wont be available for a
little while.
Until that is fixed, can you test the upgrade path from buster?
The upgrade instructions are at:
Please check that the bullseye template is a drop in replacement for
buster, and that all tools and processes work as expected, including the
Qubes Updater.
Around August 20th, I installed the brand new debian-11 template from itl-testing.
Yesterday, I started a test AppvM based on this template, as expected the Qubes Updater detected an update (DSA-4963-1 openssl) and installed it.
Then, I switched all my AppVM and DispVM from the debian-10 templates to the debian-11 templates. My sys-net and sys-firewall use also the debian-11 templates. So now, I no more use debian-10 stuff.
Also, I upgraded 2 HVM (minimal and XFCE) from debian-10 to debian-11.
I didn’t detect issues…
Tested:
[x] Qubes Updater
[x] AppVM base on debian-11 template
[x] DvmVM base on debian-11 template
[x] HVM upgrade from debian-10 to debian-11
[x] qvm-run, qvm-move, qvm-copy, qvm-open-*
[x] general usages (web-browsing, mail, terminal, open img/pdf documents)
Not tested
[ ] template upgrade from debian-10 to debian-11, and I won’t test it.
[ ] debian-11 minimal template, I’ll test it in the next days
My system is mainly debian-based. I use fedora-34 only for my builder AppVM and the default-mgmt-dvm.
If you want a specific test, ask and I’ll see if I can check it.
