joe2
October 31, 2024, 8:54am
1
As far as I understand it, it is not possible to use a template vm for another template vm, so that if there are changes made to the former then those changes show up in the latter.
Is this correct, or am I overlooking something?
It’s not possible with current template implementation.
otter2
October 31, 2024, 11:00am
3
It would be almost as cool to have as nested virtualization.
What would you like to see improved in Qubes OS? :
Be able to have a template tree. This seems more like sci-fi to me, but it would be really cool to have a template based on a template which differ by one additional not-so-trusted app installed. This would greatly decrease the space required to operate qubes. Dedup may be an alternative to this.
Snapshot tree. It should be possible to work with snapshots via gui. I want to be able to version-control my vms and revert to any of manually saved states on a whim instead of cloning them like a caveman. Please throw a link at me if this already exists and I am just unaware of it.
Very nice note on the topic by alzer89 :
But I do agree with you that there are benefits to be had from “delta templates” or “snapshots” if you will, if done right, with no compromises as far as security/integrity goes.
It would allow you to stack multiple templates on top of each other, before you overlay the qube. You could even have a single application in a template, and overlay that application (and all it’s /lib, /etc, /usr, and /opt files) across an OS template, allowing you to (potentially) hot-swap the application onto a different OS, with all its configuration intact.
Yes, there’s a lot in this that can go wrong (trust me, I realised more the more I wrote it), but that’s the point that I’m trying to make. The devs have definitely thought about cool ideas like this, realised the fact that a cool idea takes a lot of time to become a solid one, and have opted to keep it simple, and build incrementally from there.
For every solid idea, there are at least 30 other cool ideas of a Qubes dev’s machine, in various states of functionality
