Hi
I’m trying to reinstall a template but its not working. I tried the automatic way but got a errors. I emptied the cached packages (0 bytes). I rebooted, no good.
[terry@dom0 Desktop]$ sudo qubes-dom0-update --action=reinstall qubes-template-debian-10
WARNING: Replacing a template will erase all files in template's /home and /rw !
Template VM halted
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time...
Fedora 25 - x86_64 - Updates 903 kB/s | 24 MB 00:27
Fedora 25 - x86_64 2.2 MB/s | 50 MB 00:22
Qubes Dom0 Repository (updates) 248 kB/s | 1.0 MB 00:04
determining the fastest mirror (15 hosts).. done..0 kB/s | 2.7 kB 00:00 ETA
Qubes Templates repository 1.2 kB/s | 6.2 kB 00:05
Installed package qubes-template-debian-10-4.0.1-201912251612.noarch not available.
Error: No packages marked for reinstall.
I deleted the template. I tried the manual way
@dom0 Desktop]$ sudo qubes-dom0-update qubes-template-debian-10
Last metadata expiration check: 0:19:35 ago on Wed Feb 24 20:45:27 2021.
Dependencies resolved.
Package Arch Version Repository Size
Installing:
qubes-template-debian-10 noarch 4.0.6-202101091318 qubes-templates-itl 873 M
Transaction Summary
Install 1 Package
Total download size: 873 M
Installed size: 3.4 G
DNF will only download packages for the transaction.
Downloading Packages:
[MIRROR] qubes-template-debian-10-4.0.6-202101091318.noarch.rpm: Curl error (23): Failed writing received data to disk/application for https://mirrors.edge.kernel.org/qubes/repo/yum/r4.0/templates-itl/rpm/qubes-template-debian-10-4.0.6-202101091318.noarch.rpm [Failed writing body (8613 != 16384)]
[FAILED] qubes-template-debian-10-4.0.6-202101091318.noarch.rpm: Curl error (23): Failed writing received data to disk/application for https://mirrors.edge.kernel.org/qubes/repo/yum/r4.0/templates-itl/rpm/qubes-template-debian-10-4.0.6-202101091318.noarch.rpm [Failed writing body (8613 != 16384)]
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: Error downloading packages:
Tried it a couple of times. Notice that the failure point is different each time, like (4517 != 16384).
Is this an underlying hardware problem (disk is only 2 years old!), or am I missing something in the process?
