The sequence described in Templates | Qubes OS seems not right as sys-usb needs to be based on fedora-<new>-dvm
I just cloned fedora-<old>-dvm to fedora-<new>-dvm and rebased w/o going through step 4 and it works fine.
Are you referring to the following step?
[user@dom0 ~]$ qubes-prefs default-dispvm <NEW_DISPOSABLE_TEMPLATE>
Partially. I skipped all of the commands in step 4 at the favour of cloning and rebase.
By cloning the dvm template you also clone every change made to the persistent partitions. Re-creating from scratch is arguably the better option here, I donât see why youâd say itâs ânot rightâ.
This remark does not refer to step 4 but the sequence of step 1 to 4. Step 4 should be done before step step 2 IMHO.
Apologies, I misinterpreted your comment. If the vm is a disposable (as it should be for sys-usb), then yes, the template should be created before.
Iâll make the title more informative and move the thread to the Website Feedback category.
Opened a PR for this:
