I think I have an issue similar to this, but I updated dom0 and rebooted everything multiple times to no avail. Shouldn’t it be fixed at this point or the root cause is different in my case?
Overall symptoms are very similar: app qubes and disposables have the internet connection while the templates do not. One difference is that debian templates also have no internet connection.
The error in fedoras:
Function: cmd.run
Result: False
Comment: Command "/usr/lib/qubes/upgrades-status-notify" run
Started: 17:59:28.917228
Duration: 2185.83 ms
Changes:
pid:
1205
retcode:
1
stderr:
Error: Failed to download metadata for repo 'updates': Cannot prepare internal mirrorlist: Curl error (56): Failure when receiving data from the peer for https://mirrors.fedoraproject.org/metalink?repo=updates-released-f38&arch=x86_64 [Proxy CONNECT aborted]
The error in debians:
Function: pkg.uptodate
Result: False
Comment: E: Failed to fetch https://deb.debian.org/debian/dists/bookworm/InRelease Reading from proxy failed - read (11: Resource temporarily unavailable) [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.debian.org/debian-security/dists/bookworm-security/InRelease Reading from proxy failed - read (11: Resource temporarily unavailable) [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease Reading from proxy failed - read (11: Resource temporarily unavailable) [IP: 127.0.0.1 8082]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Started: 04:22:43.661335
Duration: 8491.459 ms
Changes:
I haven’t tried the workarounds from the related github issue yet.
