I downloaded the latest version of OpenOffice here, I then copied it over to a templateVM and installed it using the following instructions. After installing I rebooted the qube and opened it. Everything worked fine. I then opened the AppVM based on the TemplateVM and attempted to open OpenOffice. The Startup screen briefly flashed on, and then disappeared. I then tried to run it in the terminal, this had the same result, and gave the following error:
Application Error
Fatal exception: Signal 6
Stack:
/opt/openoffice4/program/libuno_sal.so.3(+0x37c3a)[0x729ede037c3a]
/opt/openoffice4/program/libuno_sal.so.3(+0x37d6c)[0x729ede037d6c]
/opt/openoffice4/program/libuno_sal.so.3(+0x37e09)[0x729ede037e09]
/lib/x86_64-linux-gnu/libc.so.6(+0x38d60)[0x729edd753d60]
/lib/x86_64-linux-gnu/libc.so.6(gsignal+0x141)[0x729edd753ce1]
/lib/x86_64-linux-gnu/libc.so.6(abort+0x123)[0x729edd73d537]
/opt/openoffice4/program/libvcl.so(+0x1557e1)[0x729ed91557e1]
/opt/openoffice4/program/libsofficeapp.so(+0x2352b)[0x729eddc2352b]
/opt/openoffice4/program/libvcl.so(+0x17ff32)[0x729ed917ff32]
/opt/openoffice4/program/libuno_sal.so.3(+0x36a02)[0x729ede036a02]
/opt/openoffice4/program/libuno_sal.so.3(+0x37dea)[0x729ede037dea]
/lib/x86_64-linux-gnu/libfontconfig.so.1(+0x782c)[0x729edbc9982c]
/lib/x86_64-linux-gnu/libfontconfig.so.1(+0x1cce5)[0x729edbcaece5]
/lib/x86_64-linux-gnu/libfontconfig.so.1(+0x1cfe2)[0x729edbcaefe2]
/lib/x86_64-linux-gnu/libfontconfig.so.1(+0x1d10d)[0x729edbcaf10d]
/lib/x86_64-linux-gnu/libfontconfig.so.1(FcFontMatch+0x72)[0x729edbcafe82]
/opt/openoffice4/program/libvcl.so(+0x137379)[0x729ed9137379]
/opt/openoffice4/program/libvcl.so(+0x13740a)[0x729ed913740a]
/opt/openoffice4/program/libvcl.so(_ZN3psp16PrintFontManager20countFontconfigFontsERSt8hash_mapIN3rtl7OStringEiNS2_11OStringHashESt8equal_toIS3_EE+0x35)[0x729ed9138c3f]
/opt/openoffice4/program/libvcl.so(_ZN3psp16PrintFontManager10initializeEv+0x247)[0x729ed9144247]
/opt/openoffice4/program/libvcl.so(_ZN3psp16PrintFontManager3getEv+0x49)[0x729ed914510b]
/opt/openoffice4/program/libvclplug_gen.so(_ZN14X11SalGraphics14GetDevFontListEP15ImplDevFontList+0x2c)[0x729ecf470142]
/opt/openoffice4/program/libvcl.so(+0x25ab50)[0x729ed925ab50]
/opt/openoffice4/program/libvcl.so(+0x261686)[0x729ed9261686]
/opt/openoffice4/program/libvcl.so(_ZNK12OutputDevice13GetTextHeightEv+0x12)[0x729ed9263d84]
/opt/openoffice4/program/libvcl.so(+0x264304)[0x729ed9264304]
/opt/openoffice4/program/libvcl.so(_ZN12OutputDevice8DrawTextERK9RectangleRK6StringtPSt6vectorIS0_SaIS0_EEPS3_PN3vcl11ITextLayoutE+0x195)[0x729ed9264f85]
/opt/openoffice4/program/../program/libspl.so(+0x11a1e)[0x729eca611a1e]
/opt/openoffice4/program/../program/libspl.so(+0x1129c)[0x729eca61129c]
/opt/openoffice4/program/../program/libspl.so(+0x128dd)[0x729eca6128dd]
/opt/openoffice4/program/libsofficeapp.so(+0x3c17c)[0x729eddc3c17c]
/opt/openoffice4/program/../program/deployment.uno.so(+0x54818)[0x729ec8654818]
/opt/openoffice4/program/libdeploymentmisc.so(_ZN7dp_misc16syncRepositoriesERKN3com3sun4star3uno9ReferenceINS2_3ucb19XCommandEnvironmentEEE+0x460)[0x729edc60b170]
/opt/openoffice4/program/libsofficeapp.so(+0x3c220)[0x729eddc3c220]
/opt/openoffice4/program/libsofficeapp.so(+0x2c837)[0x729eddc2c837]
/opt/openoffice4/program/libvcl.so(+0x180817)[0x729ed9180817]
/opt/openoffice4/program/libvcl.so(_Z6SVMainv+0x1e)[0x729ed91808e2]
/opt/openoffice4/program/libsofficeapp.so(soffice_main+0x9c)[0x729eddc54f8c]
/opt/openoffice4/program/soffice.bin(main+0xb)[0x400f7b]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea)[0x729edd73ed0a]
/opt/openoffice4/program/soffice.bin(__gxx_personality_v0+0xb9)[0x400eb9]
Aborted
OpenOffice runs fine in the template, why doesn’t it work in the AppVM?
Also, I don’t know if this information has any value but openoffice does open in the AppVM if I run it using sudo, this is just inconvenient and it looses all it’s data after a reboot.
Any help will be much appreciated, thanks!
