Template didn't install right
Good evening guys,
Ok, so i had a template not install right even though in dom0 it finished said it was done and its 7gb in size. It does not populate in qubes manager, or the drop down where I see all my other templates and appvms. So i tried to reinstall it but dom0 states its already installed.
I can’t unistall it from terminal becasue it gives me so long statement which i don’t recall…So where the hell do I find this template in file explorer so i can just “right click” and delete from the folder it is nested in??
Found my fix i believe…
sudo qubes-dom0-update --action=reinstall qubes-template-package-name
