Followed community guide to install tail scale in template, and bind relevant directory/modify config of an app vm.
I assume that the chmod 777 needs to be applied to 50_user.conf and
“binds+=( ‘/var/lib/tailscale’ )” needs to be entered into the file body.
I have completed the steps. Rebooted and see that my app qube is listed in my tailscale devices. I also enabled a pfsense to advertise one network.
The pfsense tailscale IP however is not reachable from my appvm, I am unable to ping it or connect to services on that network from qubes.
Is the guide incomplete, what must be changed to successfully connect tailscale devices ?
