T14 gen 4 amd ryzen pro5
seeing the following kernel panic erros on a t14 with the latest build wondering if anyone has any guidance. I believe I attempted acpi disable and no luck. Thank you!
attempted to add this via the GRUB and no luck
Where/how did you add it specifically?
hmm I add it via pressing “e” at the GRUB selector for the install qubes os option and then adding the “module_blacklist=ucsi_acpi” under the “setparams” line then pressing F10 to boot. I hope im doing it wrong?
I don’t know what setparams line are you talking about, but you need to add it like this:
At the end of the first line starting with module2.
solved thank you so much for your help!
