System76 Serval WS (serw14)
layout:
  'hcl'
type:
  'Notebook'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  System76
model: |
  Serval WS
bios: |
  1.07.13S3
cpu: |
  Intel(R) Core(TM) Ultra 9 275HX
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device \[8086:7d1c\] (rev 01)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Arrow Lake-S \[Intel Graphics\] \[8086:7d67\] (rev 06) (prog-if 00 \[VGA controller\])
  NVIDIA Corporation GB205M \[GeForce RTX 5070 Ti Mobile\] \[10de:2f58\] (rev a1) (prog-if 00 \[VGA controller\])
  Intel Corporation Device \[8086:7f2f\] (rev 10)
gpu-short: |
  FIXME
network: |
  Intel Corporation Device \[8086:3102\] (rev 04)
  Intel Corporation Wi-Fi 7(802.11be) AX1775\*/AX1790\*/BE20\*/BE401/BE1750\* 2x2 \[8086:272b\] (rev 1a)
memory: |
  64957
scsi: |
nvme: |
  26011L801769         WD_BLACK SN8100 2000GB                   830ZRR0A
usb: |
  3
certified:
  'no'
versions:
- works:
    'yes'
  qubes: |
    R4.3.1
  xen: |
    4.19.4
  kernel: |
    6.18.31-1
  remark: |
  credit: |
    skyvine
  link: |
    https://forum.qubes-os.org/t/system76-serval-ws-16-serw14/43001
Remarks
No issues encountered in my workflow, which is primrily based around terminals and web browsers. Playing video worked fine. The bluetooth adapter and camera appear as USB devices, I have not tried to use them.
I’m not sure what to do with the remaining FIXMEs.
Leave the generated HCL alone, run these tests:
Test Name Test ID Result
Installation QBS001.001
Boot QBS001.002
Reset Button DPC001.001
Wakeup Flag SUSP001.203
Press Key SUSP002.203
Power Button SUSP003.203
Display Resolution DSR001.001
PS/2 Keyboard PPS001.001
Ethernet N/A
Wi-Fi N/A
In sys-usb, run lsusb and paste the output.
I’m a little confused about the “FIRMWARE: Dasharo” part because this laptop doesn’t use dasharo firmware, but I went through the tests anyway.
Installation QBS001.001 PASS
Boot QBS001.002 PASS
Reset Button DPC001.001 N/A
Wakeup Flag SUSP001.203 PASS
Press Key SUSP002.203 FAIL
Power Button SUSP003.203 PASS
Display Resolution DSR001.001 PASS
PS/2 Keyboard PPS001.001 N/A
Ethernet N/A
Wi-Fi N/A
Output of lsusb with no peripherals attached:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0627:0001 Adomax Technology Co., Ltd QEMU Tablet
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 003: ID 04f2:b865 Chicony Electronics Co., Ltd Chicony USB2.0 Camera
Bus 004 Device 005: ID 8087:0036 Intel Corp. BE200 Bluetooth
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Okay, last remaining tests are Ethernet and Wi-Fi, do they both work or not?
