Would it ever be possible to once again make Qubes OS versions where it is a bit more relaxed on system requirements?. I am thing specifically about the
Intel VT-x with EPT or AMD-V with RVI
Intel VT-d or AMD-Vi (also known as AMD IOMMU)
Because i think that sorts out many pc’s
I see some of the earlier qubes versions did not have those requirements. But maybe it is a nessecity to demand those requirements to make sure the OS gives the protection it is intended to provide?
One more question. If i can not meet the hardware requirements, would i then be best of using an earlier Qubes OS version? Or would it provide better security to just run another linux OS?. I am here thinking about which would be the safest way to run an whonix os virtual machine?
Qubes alone doesnt make the rules in this case. Xen wont fully work without IOMMU especially the seperation from PCI hardware devices from dom0 (sys-net, sys-usb, sys-gui-gpu etc…)
so if you override these requirements you probably just have a bloated linux.
