Today i made a fresh install with qubes 4.1 and because i dont have a ps2 connecter i am forced to use a usb keyboard. So after i finished the install and updated everything i wanted to create the usb qube with this command:
sudo qubesctl state.sls qvm.usb-keyboard
everything worked? but when i rebooted and used my encryption password the system wouldnt boot. So i tried again with a fresh install and before executing the same command i tried to install the package that is listed in the docs:
But this only gave me the error curl 37 and that it couldnt open the file and that the package is already installed. So i checked the version that is installed with the latest one in github and just tried:
again. But after rebooting and decrypting it just hang itself up. In the picture is the output (i censored some stuff bc i dont know what i should and shouldnt share)
A ryzen 2700x and a GTX1080. Because i only have one pc i have a dual install with windows and fedora on the internal disks and Qubes on an external. But everytime i load qubes i deactivate the sata ports in the bios
I’ve seen many errors caused by installing qubes into external drive, from the log you provide the main problem is not sys-usb thing.
Could you let the sata ports activated and see what happen?
and if it’s still like that.
Maybe this could be one that causing the problem, could you run qubes installer medium and boot into rescue qubes os, after wait for some time, press 3 to skip to shell and run lsblk, efibootmgr -v
There’s a different booting with internal or external (removable) drive in uefi,
normally that qubes efi file are located in / boot/efi/EFI/qubes/
when you do installation the efi file are installed in that folder, to boot from removable device in uefi, simply copy all of them to /boot/efi/EFI/boot/
and create an uefi entry pointing to this boot file.
