Hello folks,
I have a big concern on how these work together.
I use a few VMs in Qubes connected to sys-whonix and I can’t control the ExitNodes. This gives me headaches. I tried to understand but I couldn’t
- at sys-whonix (the gateway) level a TOR circuit is established
- at whonix workstation level
– using TOR browser, there is another TOR circuit established on top of the sys-whonix? I remember I read somewhere that is not good to have more than 3 nodes (including entry and exit nodes) in TOR network. Anyways, it seems there is a different circuit than the one sys-whonix creates.
– using CLI seems to keep the sys-whonix circuit, though, Im not sure. - at a debian-based VM level which is connected to sys-whonix using Firefox it seems to be a different TOR circuit than sys-whonix
Once the sys-whonix establishes a TOR circuit, logically is to provide that TOR circuit to all the VMs connected to it either if the VMs establish browser/app connections or CLI connections, right?
I really don’t understand how this works. If someone can tell me or point me to a document it would be great. Or tell me how can I test it, maybe I didn’t test it correct.
Thank you.
