[sys-whonix] - "Time synchronization result: systemcheck gave up waiting." upon startup using the systemcheck command
Hi, qubes newbie here. Every time I start up my computer, I run the systemcheck immediately to make sure the whonix gateway is running fine, but this is the error I get every time. I’m pretty sure the whonix gateway still works since I can browse the web through tor and the browser says that my tor connection is not managed by the browser (I’m assuming the gateway is providing it).
I’m trying to follow the troubleshooting steps that the output has provided, such as B), but when I use the sdwdate-gui command, it gives me “tor_status was called”. “tor_status status: tor_disabled” “_init_: ERROR: sdwdate_gui_server is already running!”
sdwdate
Edit: I restarted the sys-whonix qube from the qube manager and it looks like everything is all good?
Yes, all clear.
Im having this problem but the solution didnt work for me, any other suggestions.?
