Sys-whonix: running but disabled
Hello
I have (i believe) a current fully upgraded version of qubes and its been working perfectly for a long time now, but I just noticed yesterday that if i check tor status using the Time Synchronization Monitor icon then the status of tor is running but disabled. It also provides information to rectify this but (and i am no expert on this) tor seems to be working perfectly. I also seem to remember that this is new to my system and every other time i have checked this it has indicated that tor is running.
So the question is, What is the default behavior. Do i leave it as it is or do set the DisableNetwork option in the torrc file to 0. I am also interested as to why this has happened. I wonder if it was some time ago when I upgraded my debian-13 template, and I just haven’t noticed it.
any help appreciated
Thanks
I had the same thing happen.
Menu item “Whonix” → “Tor control panel” → Button “Configure” → Drop down menu “Bridges type” → “enable network” → Button “Accept”.
Tor is running and comes back with VM restarts.
Thank You.
That has restored it to what i had before.
Just out of curiosity when the working but disabled message appears. Does that mean that tor was not working?
I noticed the same message. It fixed it but what caused it? I didn’t change anything from the default.
Tor is running but the network is disabled.
A line DisableNetwork 1 exists in torrc.
Therefore, you most likely cannot connect to the internet.
The network can be enabled by: Configure → Bridges type → Enable network → Accept
